Enables IP forwarding over MPLS LSPs for the default VR.
Disabled.
This command enables IP forwarding over MPLS LSPs for the default VR. When enabled, LSP next hops can be used to tunnel IP traffic across the MPLS network. By default, IP forwarding over MPLS LSPs is disabled.
The following command enables IP forwarding over MPLS LSPs:
enable iproute mpls-next-hop
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
